stevel3007
I rebuilt my 77 440's a couple years ago and I noticed on one engine at first startup that it had a bit lower than normal oil pressure at cold start than what I would have expected. Instead of the typical 60 psi, I got 40-50 psi. Still ok but not clear why it was a bit low. The rebuild engine had all the usual stuff - new bearings, gaskets, seals, timing system, Melling oil pump, pistons, rings, etc and a new Edelbrock 1409 marine carb. Using 10W30 oil currently. Aside from the carb, all stock parts. Engine ran well except the oil pressure concerned me and the valve train seemed a bit "clacky" compared to my other engine.
Fast forward two years (with little use) and this is what I am seeing....
Cold start sees about 40-50 psi, then drops to 20-25psi once warm. I have been running the engines easy at 2200rpm max due to the oil pressure issue. I put a mechanical pressure gauge on today to confirm what I was seeing on the console gauge. Wiggles a bit when running but clearly < 20 psi.
What is really puzzling me is that rev'g the engine I see a slight DROP is oil pressure. The opposite should be happening! - So why is this happening?
My thinking is this may be due to:
- bad bearings (on a rebuild with < 50 hours all checked w plastigauge at install? seems a stretch)
- [stock] pickup tube is above the oil level and cavitating (however, dipstick is full; added another 1/2 qt of oil no change)
- oil pump pressure relief valve is stuck open
I'm leaning towards the oil pump as my problem (all along) and about to pull it off.
Other ideas?
Other ideas?
