Thanks I'll do that.I don't have the service manual for that engine but a basic initial mixture adjustment of 1 3/4 to 2 1/2 turns out from lightly seated should get the engine starting and idling.
Then, it needs to reach operating temperature and the idle speed set before synchronizing the carbs.
If it still hesitates on acceleration after synchronizing, it's likely that there is a problem with either the dashpot diaphragm or the accel/decel check valve. If those are OK then carefully inspect the accel/decel hoses for defects or leaking.
Good luck.
I want to thank you for your information it has got me up and running again. I'm out three turns it's running great just a real pain to get started. Thanks againThanks I'll do that.
I removed it and it's extended I can push it back up but it just fully extends right away. Your exactly right about removing the carburetors again lol. With that bystarter being extended I'm going to replace that.I realize...and can appreciate....that you're trying to avoid removing the carbs again.
BUT, unless you remove the bystarter first and find that it is stuck in the extended position, you really have no other option in solving the problem. The bysyarter pin not retracting is RARE. I explained how to check it in post #10 of this thread.
My guess is that the problem is more than likely the little feed channel in the BOTTOM OF THE FLOAT CHAMBER is plugged and not allowing the bystarter well to fill with fuel. Already discussed in post #5 and #7 of this thread.
You've already said that you didn't clean that so GO BACK and make sure it's TOTALLY CLEAR. It is a BASIC part of PROPERLY cleaning the #1 carburetor on this engine.
I fully explained how the bystarter works in post #12 of this thread. Go back and re-read that.
In doing that. I hope that you can understand that the bystarter needs NO POWER going to it in order to supply enrichment fuel to the carburetors for cold start.
Good luck.
Jgmo: you were 100% right the bowl was clogged took awhile but I was able to get it cleared very hard getting anything in there I used 20lb fishing line to get a idea how far in the tube it was clogged and couldn't get anything in that far thank God for air compressor and can of carburetor cleaner. I finally got it motor started right up but had it running before I took the carburetors off it ran a little high then settled down to a good idle. I'll give it a start in the morning but I'm feeling really confident it will start right up. I owe you a great thank you for sure if it wasn't for you I'd still be messing with the ruff running and probably would have sold it lol. Big thanks againYeah, run a stiff wire through that tunnel then hit it real good with carb spray. Even if it's only partially blocked it will cause starting problems.
Hopefully your valves are properly adjusted and timing is correct. If you're not positive, you should check all that before taking off the carbs.
Good luck.
