My motor has no voltage regulator, only a rectifier. 1986 Mercury 75HP. I get fairly regular voltage spikes that shut down my more sensitive electronics, like my Garmin fishfinder and stereo. The FF has a voltage reading that shows 16.5v sometimes 17v before a voltage warning and shutoff. Experienced guys tell me the battery acts as the regulator in this motor. My battery is less than two years old and tests good at Pep Boys.
I got my hands on a voltage regulator. This one: https://www.amazon.com/MZS-194-5279-Mercury-65W-81960-00-00-65W-81960-10-00/dp/B074DCX2G4
I want to pull out my rectifier and wire this thing into my motor and see if my voltage settles down.
It may not work, but it won't potentially hurt anything, will it? My only variable is the ground. The rectifier in my motor now uses the base as the ground, I assume this rec./reg. case is the ground, so I'll have to get creative about mounting it and running a ground wire.
Anyway, my main concern is damaging the motor just by trying this.
