the_last_hour
When I had my 350's compression checked, one motor showed lower compression by about 10-15lbs accross all cylinders than its sister. The lower compression engine runs 2gph less efficient at cruise than the other when synched on rpms, and the difference moves up to 5gph when secondaries jump in. The stamps on the props are matched as far as pitch and diameter, but what would happen if I reduced the pitch on my less efficient motor. The rpms would increase on the less efficient motor so I could back down the throttles a little compared to the other one, thus synching up the fuel flow. Is that a bad idea?
