I have a c40tlrx that is running poorly. I have rebuilt the carbs and set needles to factory spec at 1.5 turns, new fuel pump, new fuel lines with new clamps and connector and cleaned the fuel tank and tested for air leaks and vent clearance. Seems to be getting fuel. It is bogging down like it needs fuel at all throttle ranges but at <1000rpm it backfires and wants to conk out at <800 rpm. Another tell tale is the sooty oily residue it is spewing. Compression is 124/123/124. Using a factory service manual and peak voltage Multi Meter (DVA) I went through the trouble shoot sequence listed.
1-Checked SP gap at .10, good. Tested spark at 9mm good and bright
*2-CDI Output- cranking spec is 125v I was showing 9.5-11.5v, I tried switching between ac and dc and got the same and got sevral readings ranging from 200v-400v on AC
3-Measured coil output @ cranking and was 145v, good
*4-Measure Pulser Coil- Get different readings on each pin, 7.9v-9.4v-15.1v (spec is 3.0v @ cranking)
* This is my issue: the CDI output and Pulser coils utilize a three pin harness, which I dont have so I tested the pins individually. Can I assume that these readings are correct or incorrect. Shade Tree "Algebra Kicked My Ass" Logic tells me that each pin is responsible for firing a specified (same or close to same for each) charge thru its circuit to fire the coil that in turn fires a charge to the plug and that reading should be obtainable from each pin, however, this being the world of outboards is similar to the platypus in which all scientific rules are tossed! lol
Question: Can I use individual pins to test the elements as per specification or do I have to purchase a test harness adding $50 to the cost of what, based on my backyard analysis and the manual say, to be a screwed up CDI?
($400-$500! ouch)
Followup if yes I need a harness, Can I make a harness that essentially allows me to read the three pins on one red MM test lead and then ground the black MM lead to the engine block? Im assuming if I do that I could possibly backfeed, for lack of a better term, each of the circuits and then I will definitely need a new CDI which while I would know that the CDI is f'd I would still have the original issue lol
On one other note I did run the engine without the R/R plugged in and it still ran like crap! I was hoping that was the issue... no dice
