brettdawnj
I just got done looking at a 1997 9.9 Honda 4 Stroke Long Shaft Outboard Motor. It really looked great with virtually no signs of visual wear or damage except for the paint flaking off the cowling.
Started great, sounded great, but the tell tail water pee stream was not working... no water coming out. Made me concerned and didn't run it too long. I could feel the engine getting warm to hot so I shut it down.
Took the plugs out and did a compression test on the cylinders. Both read about 110 psi (spinning it over with the electric starter so the revolutions were quit high). Manual states the spec is 156 +/- 14 (or from 142 to 170) if I remember correctly. With this level of compression drop, is this a major concern? Or will this engine still have a good service life and performance at this level? How low can the pressures go and still have a decent engine?
The owner stated when he started it yesterday, the pee stream was working. He is going to install a new water pump impeller to see if this corrects the issue.
The owner wants $700 for the outboard. Does this sound reasonable? Or should I just walk away from this one?
Thanks,
Brett
Thanks,
Brett
