"Can anyone help me to figure
"Can anyone help me to figure out if I have a charging issue or what is happening in normal? My charging indicators which used to run about 13.5 volts and could be influenced by the throttle hover in the 10-12 range. The batteries when checked by a volt meter are 12.39---12.62. I took my genset battery and switched the wiring to check if I could have a bad battery...recently I had to add about a pint of water to each battery because the dock side charger must have boiled away some of the acid. This didn't make a difference at the gauge. The engines start fine, is it that the batteries don't need any additional volts or are the batteries somehow effecting the alternators charging...just seems strange that both engine chargers are messed up at the same time?"
