Hi guys, new to this site, I have a pair of AQ151c's, my problem is that my starboard engine overheats, its ok at 6-10 knots but if I give it some welly 17knots or more within about 3mins it over heats then I slow down to let the engine cool for about 10mins, but now the engine just cuts out, I have checked the intake connected hose and pumped overboard, the raw water pump serviced new bearings,shaft,seal and impellar and gasket, took the heat exchanger off and took apart and cleaned, strobe to timming shows 10degrees after TDC so I know I will have to ajust Distributor, but if timming out will this make it overheat, any advice much appreciated.
T1ony
T1ony
