pugetsounder
Advanced Contributor
"Took the boat out for its sec
"Took the boat out for its second sea trial after almost sinking it on the first one. This time we had better luck! Found a few leaks that were easy fixes. The seawater strainer cap was spewing but took it off the cleaned the gasket. Also noticed water weeping in around the rubber connector from the exhaust mani to the exhaust pipe, so I tightened the clamp a couple of turns. I will definitely get a bigger sump pump. I'm running a 400 GPM now would like 650-700.
Anyway to my problem. A boat acts way different in the driveway on a hose than it does under load in the water. At idle in neutral it is a fairly smooth acceleration. Under load it really hesitates between 1000 and 2000 rpms. After that the motor runs fairly smooth. At first there were hesitations at all rpms but as the motor warmed and the more we ran it the better it ran. We tried to run it hard on purpose. Lot's of start and stops and some WOT for a bit. But there is always a hesitation coming off idle and the idle isn't always smooth. And when it's warm it idles higher than when it's cold (1100-1200rpms) which is causing me hard shifts. I'll do another complete tune-up and I am waiting for my Uni-sync tool to come in the mail to set the carbs. I didn't check for moisture in the dist cap or check the point gap yet. Anybody else have any other suggestions? I am hoping not to rebuild the carbs if i don't have to."
