Is there any way I can tell if
Is there any way I can tell if anything is broken inside my motor with not taking it apart.
I think the head gasket went bad while it was running. So as it stalled and I tried to start it before I realized something was wrong. It cranked very slow and I think it hydro locked. I have no compression on some cylinders.
Before my trouble started I had a linkage problem with shifter so I had to back up against the current. I am new to inboard/outboard motors
Could my engine sucked in water from exhaust?
All I know is it was running then just stalled out
and when I raised hatch I saw water come up through carb when I crank motor.
I did remove spark plugs to get water out from cylinders. So my question is can I tell from taking spark plug out and seeing if piston moves.
Or how do I remove head to check condition of engine
