Pbdy Jr
I have a regulator wire traveling to the choke, and the other wire travelling to the starter slave solenoid. With the Ignition turned on, i get twelve volts through these wires. If i crank the motor, it drops to 9 volts. However, these readings are with the power unhooked from the coil. When i hook these wires back up to the coil, they read just over 5 volts. these wires heat up pretty quickly and I have no spark coming from the coil.. I am going to replace the coil, but I want to make sure this voltage is behaving as it is supposed to.
