Jeff Cowley
Hi, My 35 foot Riviera powered by twin AD41Bs is smoking heavily from the port engine & covering the boat in black soot.
I have just aquired the boat & sailed across Bass Straight (approx 23 hours) & noticed the problem worsened during the journey.
The previous owner has replaced the turbo, reconditioned the head & fitted new injectors to the engine.
I am new to these engines & diesels particularly & am seeking advise as to where to start to remedy the problem.
I have removed the air filter & the turbo spins freely & appears to a novice to be clean.
The pipe from the turbo to that aftercooler is also clean.
Refuelled after the first 2 hours running & used 57 litres per hour (both engines) cruising at 12 knots, 3200rpm & flat seas.
Expected to use approx 40 litres per hour. The engine didn't use any oil on the journey & the problem seems to be with the fuel system.
All & any advice would be appreciated.
