bought a fishing boat with a 99 Johnson 175 carbureted 2 stroke. I’ve had it in for work since it started sputtering out a lot, was told I had water in the fuel system and apparently it was all sorted out. I’ve got it to the point where after I prime it and fire it up it will run at idle after a few minutes then it will sputter out. I’ll re prime it and it’ll fire back up and run a while longer and sputter out. It seems as if the primer bulb is going empty on me each time but each time I prime it (until it feels hard and solid) it runs and eventually idles perfectly without going out on me. Now when under throttle it has issues getting up to speed and starts surging a lot. To get it going I have to ease the throttle up bit by bit to get it to hold speed under high throttle. It sometimes will still start to surge and die right out. Some days it runs just fine without issue though without any problems. I’m really having trouble diagnosing this.
