I have a 2018 Mercury 9.9HP 4-stroke. The motor speed does not increase until I turn to about half throttle. When I checked out the throttle controls, I found that the throttle opener does not move until the throttle drum turns about 90 degrees. The bolt that runs through the throttle opener and throttle drum appears to be loose. There is not enough room to get a wrench on the bolt head. Any suggestions on what I should do?
