notherboat
Is there supposed to be enough gap between prop and prop nut so the prop can move in and out a bit on the shaft, or is it supposed to be tight?
Mine is able to slide a little back and forth on the shaft with the nut tight enough for the cotter pin. I thought of filling in the gap with washers if it is necessary to make it tighter.
