"Update...
Temps Riser 118, 1
"Update...
Temps Riser 118, 123 Manifold 175, block 163
Checked oil, no white milky substance,
in a nutshell
no smoke, checked oil qt low so i added one qt. began to smoke, temps were high too. so now temps are low but still smoking. white smoke smeels sweet dissipates 10' off stern. so i changed the plugs and am waiting to get the oil remover so i can take the qt out that i put in. the dipstick reads just above the bottome dots that say add a qt. so the oil is right in range according to dipstick... the plugs were a little oily though, so i did change them. also at idle just exhaust comes out. at 1500 not notiable either. under load at 2000 rpm it billows out, at this point engine runs rough too like it is like it is trying to blow that oil out."
