readyforescape
Boat is 2004 Gibson 5000 with twin 8.1Ls. Stbd engine has two problems:
1- Fuel Pump is intermittent.
I have a remote start device and when powering the ignition (no start), the fuel pump will sometimes run for two seconds but most times remains silent. If I leave the ignition on for say 10 minutes, the fuel pump will run intermittently/spontaneously . After observing this intermittency many times,
I have done the following:
Checked three fuses in fuse block - all good and measured 13v
Checked system relay which clicked each and every time the ignition was powered (no start)
Replaced fuel pump relay - no change in intermittency
Wiggled the relays, relay cables, ECU connectors and cables - no change
Measured constant 13v at fuel pump relay pin 30 (no ignition) and at pin 86 with ignition (no start).
Activated the fuel pump by jumping contacts 30 and 87 at the pump relay
Confirmed continuity between ECU J1-6 and pin 85 at the pump relay
Measured voltage at relay pin 85 when powering ignition (no start). Before and after powering ignition, the voltage measured 13v except for intermittency times when voltage measured about 0. This indicates ECU was not consistently grounding pin j1-6 upon powering ignition (no start).
It seems the j1-6 signal is intermittent even though the ECU is constantly powered.
2- the buzzer ECU pin j1-8 does not go to ground after two seconds with ignition on, no start (buzzer constantly buzzes). However, this problem occurred about a year before the fuel pump problem began.
Insights, troubleshooting, solutions would be appreciated.
Thank you.
Thank you.
