"I have yet to check the compr
"I have yet to check the compression...i can do that no problem but I think it would check out okay.
I have put fuel into the cylinders and have only received a pop or two out of it. Also a shot of starter fluid into the cylinders only gave out a pop.
The only time that the engine has run for a period longer than a second was when I hit it with starter fluid in the carb. I did that and pulled on it and didn't get anything but then after waiting a few minutes and trying again it ran for a couple seconds and then died.
It still just blows me away to see the fuel coming out the carb.
Yes, JB has an excellent point - it may be trying to exhaust when it should be "breathing" or something in between....
This is stuck in my head. I was screwing with it today and while I had the carb off I put my hand in front of the hole for the carb in the manifold and it seemed to be blowing air out of the hole when I cranked the engine. Shouldn't it be sucking air in? I am going to look into this more.
I was thinking of rigging something up to see whether the carb hole is exhausting air or sucking air in...something with a vacuum gage or something i dunno.
Eventually this will get figured out...}"
