"Had a complete rebuild on the
"Had a complete rebuild on the Port engine and have never been able o get it running right . The Tech can not figure out the issue, he just keeps throwing parts at it...To the issue.
At idle it is running somewhat ruff, when put in gear the engine stalls and dies sometime. Replaced injectors and Idle motor and it will not stall when in gear now, but when you power up it gets to 2400 RPM's and sputters and shuts down to idle speed. Tech says the timming is good but that would be my guess. He did install a new distributor with the rebuild and says you cant install it wrong because it only goes in one way. Any help would be greatly apreciated."
