good times
This is a 2013 4 stroke engine with few hours on it. last run fine in December. No work or maintenance etc was done on the engine- well, we checked the oil..
It starts, runs fine but cannot be shut off with the kill switch - as a matter of fact (and surprise), the engine revs up a few rpms when the kill switch is pushed or pulled or the safety clip removed - I have to disconnect the fuel line and let it die...
took the kill switch apart, looks brand new, no corrosion; manually disconnected the brown wire from coil and it shows about 14V from there (the brown wire terminal) to ground. take a spare wire and connect this terminal to ground and engine revs up too.
I call it the miracle engine; seriously, what am I missing..
