Hi,
I have two 454 - 350hp built in 1988 in my 1989 Tiara. The port engine is leaking oil from, I believe, the rear crank seal. Problem is, I'm not sure if this engine has two bolt mains and consequently a two piece seal, or four bolt mains with a one piece seal as is the case with current engines.
I sent the serial number to Crusader, and they said the records back then were incomplete, but they believe it to be 4 bolt. Some old Crusader exploded view drawings dated 1987 say it has 2 bolt mains and a two piece seal. The transition from 2 to 4 bolt occurred sometime around then.
I'd like to pre-order the seal and oil pan gasket so I can be ready when I remove the motor, but what to order?
