"OK, I have the cooling and ch
"OK, I have the cooling and charging systems repaired thanks to you men. Now if someone can tell me about a power steering leak I'll be in good shape. The power steering system has a belt and the fluid reservoir behnd the pulley. It looks like an auto type setup. I fill the reservoir and it leaks down into the bilge. There is a small hose running from the rear of the reservoir down under the engine and that is where it leaks. I can't see under there and I am totally unfamiliar with the setup. Can someone please give me some advice. Thank you, Bob"
