Engine runs fine but then intermittently dies at full throttle. It restarts without any issues and runs for a while then dies again. Seems to run ok at slow speed. I did notice that the pee stream was very hot on several occasions. Pee stream is strong and constant. Is there a temperature sensor that kills the motor if it gets too hot? I did check the thermostat in hot water and it opens fully. It doesn't sound like a fuel issue because the engine seems to die quickly, not sputter like it's fuel starved. Any ideas?
