Carloux Du Preez
I have a Honda bf 150A. It Had its 500hour service in October 2014 and at this time now the hours are 631.
When I start the engine, there is a beeping noise for about a second and then off for a second, but it continues indefinitely.
Also the lights on the TACH display shows solid for oil and a triangle with its apex down on the engine fault.
I Have checked the water seperator, checked oil, and checked sensors for loose connections but all was good.
I read a bit on the forum and discovered that it has a fault code of 7 blinks (IE TP sensor) correct me if im wrong.
I have unplugged the tp sensor cleaned the terminals and re plugged it.
Then i did a reset of the fault codes by bridging 2&4 of the dlc connector and pulling the safty switch 5 in and 5 out.
Any suggestions?
Thank you in advance
Carloux
Any suggestions?
Carloux
