I have been trying to help out a guy with BF225 2006 1600 hrs that runs but would not go up on plane. Connected DR H no codes. Tested ignition coils and injector with DR H could tell #6 was off so replaced #6 Coil and all the plugs ran great dry when I barked it. But with muffs on engine wagged a bit but revved up fine. Splashed it tried to get on plane, would rev but no power. dragged home and Pulled intake cover and noticed couple ounces water in the black intake and signs of steam cleaning in #6 intake pipe. shook it out, dried it off put back together, thought this might just be from VSt water hose that popped off. Ran it again on the hand tank with concentrated injector cleaner. Still wagged at idle. Pulled #6 plug and 02 sensor found water on both. Get this, oil is not milky and I did a compression check with snap on gauge #6 with the wet spark plug shows 190psi and holds it same with #4 On other bank #5 and #3 are at 170. So water not coming from combustion chamber portion of head. must be a pin hole either before it or after it. After running engine dry no hose water to clear it out, then turning flush hose on the 02 Sensor was completely filled with water. But water had not made it back into the air intake black box I'm hoping its the exhaust manifold as I can get that fairly easily. Ideas Anyone?
