Chris actually does this for a living so I would listen to him. If you look in your newly downloaded MEFI 4 manual you will see your engine should have 41-47 psi prior to start, 37-43 psi at idle and 44-48 psi WOT. So the pressure should go up, not down as the thottle is opened. And frankly your "good" engine (36 at idle, lower at WOT) sounds sub-spec as well.
Off road and hot rod guys like these marine engine controllers. Pirate 4x4 has a good article on the system with some interesting links.
CaboJohn
CaboJohn
