Greetings everyone, this is an odd one. After running for 2+ hours at 3/4 throttle, if I attempt to slow the motor is sputters and stalls.
This is what I've tried so far:
Replacement carburetor
Replaced fuel hose (tank to engine) + bulb - as a test: if I dis-connect the tank end while running the motor it sucks the bulb flat (proves that no air is leaking)
Put a re-build kit in the fuel pump
Replace the fuel filter
Changed out the fuel lines from the pump to the carb.
The problem persists.
Get this: Once it stalls it 'always' restarts but will not run at low speed - 1/2 throttle or above it runs fine - sounds great.
If repeating the attempt to run slow with many re-starts it will 'eventually' run at lower throttle settings - can take a number of tries (5).
I've worked on MANY engines over the years but this issue has me stopped cold.
If anyone has seen this behavior and has a cure I'd be forever grateful.
Jan
Jan
