2003 johnson 90 hp trim
sinner
my 2003 90 hp johnson has run
my 2003 90 hp johnson has run perfectly for 5 yrs but it has developed a trim problem when i trim it up after use i will lower about 6 inch to a foot . is this a adjust / new or rebuild situation.
thank you george
"George.... I assume that you&
"George.... I assume that you're saying that after triming to the full up position, the engine will drop down a foot, then stop and stay at that position.
If so, raise the engine to it full height and lock it there. Fill the reservoir to overflowing. Insert the reservoir plug/screw. Operate the PTT up and down a few times, then refill the reservoir to overflowing again.
Hopefully that cures the problem. Let us know.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
joe your assumtion is correct
joe your assumtion is correct .the unit now will drop down completely overnight hopefully the same procedure will be the fix
thank you again george
