Hi,
I wanted to know if my engine will run if I disconnect from the terminal the tan wire coming from the diode the engine will run?
I am trying to troubleshoot why my engine will sometimes slow to 3000 RPM without any alarm (oil or temp). I already discinnected the temp probes on both side. I opened the top of the engine and wanted to disconnect the tan wire that is with a diode and the temp probes on the connector. I did check the diode and seems good.
