the previous owner of my 2001 50 hp 4 strike evinrude said he never used the trim. He also said he had to tap it with a screwdriver to make it work. I have the same problem. I took the motor off and it works great. I put it back on and it worked for a bit nad then went back to the same problem. If it is switched on and you tap on the unit, it will work as long as you keep tapping it. how do
i replace the fluid? Any thoughts on repair? HELP!
