tboltmike
This is the first real problem that I had with my 1975 115 Johnnie.
Had it out the week prior to the problem and it ran with out problem. Normal RPM and speed. Started it on the hose prior to the next outing and it sounded off, but not like a miss. It started just fine. Started pulling plug wires and only #2 didn't change sound and speed. Used one of those spring adapters between the plug and the wire and attached a jumper. It would jump a 1/2 inch blue spark. The plug was cold and wet.
It would start right up on 3.
Any ideas where to start. Haven't had a chance check compression
