1998 Suzuki DT200 warning buzzer problem
jcsurvey
"I have a pair of DT200's.
"I have a pair of DT200's. When ignition is turned on, either engine, I get the normal warning buzzer and lights coming on and going off for heat, oil, rev limiter, but after 4 or 5 seconds the warning buzzer comes back on for 1 second and off for 6 seconds. The warning buzzer continuously cycles, 1 second on and 6 seconds off. It continues after engines are running. No associated warning lights come on. The engines seem to run normally, don't overheat and seem to be getting plenty of oil. I have replaced the oil flow sensor and screens for both engines at the suggestion of Suzuki rep. but the buzzing continues. The service manual has no mention of a warning pattern like this. Dealers seem to be stumped. I would appreciate any suggestions."
"John, try disconnecting one s
"John, try disconnecting one sensor at a time until either the buzzer stops or you determine the buzzer is the problem...."
"Thanks all for your suggestio
"Thanks all for your suggestions. This was a litle known (got the suggestion on how to repair from Suzuki) buzzer warning for low oil flow. I emptied both oil tanks and flushed them with gasoline. I found an "Aluminum seal tab" down in the port oil tank, apparently from a gallon jug of oil poured in before I bought the boat. The warning buzzer stopped after both engines were started and running."
