Replacing the water pump on my 1994 Johnson 50/35 jet drive. RTV was previously used to create a gasket on the lower unit exhaust port where it mates with the midsection. Motor has run great like this. This time around the RTV needed to be removed as most of it had fallen off. The manual doesn't call for any sort of gasket here. Should I leave it bare or use something like Permatex Aviation Form-A-Gasket, watch I have on hand, to make a gasket?
A second, related question, is what should I grease the driveshaft splines with before re-installation? I have OMC triple guard, Green Grease and Quicksilver 2-4-C type 2 grease (jet bearing grease) all on hand.
