suffysufrin
I have a grady with twin '94 Johnson 175 loopers. When I turn the key to the pre-ignition (accessory) position on my starboard motor, the continuous warning light immediately sounds. It's loud and hurts my ears. I want it to stop. This happens whether the starbd. motor's been run for a while or whether it's been dormant for days. When the motor is running, it continues to sound. The motor seems to run okay, but hiccups intermittently from time to time. Could a bad vacuum switch cause this? THe port motor runs on the same tanks and fuel systems, but runs fine, with no warning horn.
I'd llike to replace the vacuum switch, but I have no idea where it is. Is it within the engine? Is it near the fuel tanks or in the bilge, near the fuel water separators? If I knew where it was, I could probable replace it rather easily. Please help!
