nightstalker
Took my vessel out this AM. Wind was 30MPH+ and waves were ripping (4 to 6). Engines started right up and got to operating temps. (165), oil pressure at 40. Got out of the marina and ran into those foul seas. Ran her at 3500 RPM'S, but she only reached 12 knots. It was like the trim tabs couldn't get her on plane. She seemed to be laboring to get over the top. She was throwing a large wake. I also noticed that the engines were pulsing white steam/smoke and the starboard engine was running at 190 degrees. It would blast out for a second then stop for two seconds or so. They pulsed steam/smoke like this most of the hour I was on the water. It was very rythmic, you could set a watch by it. When I tried to put the boots to her, both engines could only reach 3900 RPM'S and 14 knots. I've never been out in weather like this before, so I didn't know what she'd do. She usually reaches 4300 RPM'S and 23 knots at full throttle. I have to go back tomorrow to check her out. I think she's got bad fuel. I'll check the oil, antifreeze, fuel/water seperators as well as those trim tabs. If it is bad gas, what type of pump can I use to safely remove it from the fuel tank. I've got about 80 gal. of gas left that I'll burn in my truck. Any thoughts? What else should I check?
Nightstalker
Nightstalker
