1989 DT115 NOT CHARGING
dsmorse61
"MY 115 RUNNUNG AT 10-11 VOLTS
"MY 115 RUNNUNG AT 10-11 VOLTS IDLE AND CRUISE. VOLT READINGS TAKEN AT THE BATT. CONNECTIONS CLEAN AND TIGHT, NO OBVIOS DAMAGE TO CHARGE CIOLS, RECTIFIER AND HARNESS ANY IDEAS?????"
you need to check the charging
you need to check the charging fuse under the cowling
next u need a dva to test charge coil
"THE FUSE IS GOOD, CHARGE COIL
"THE FUSE IS GOOD, CHARGE COILS AT 4.6 VOLTS A/C WHEN CRANKING MAX AT 9.9 VOLTS A/C RUNNING FINALLY GOT A HOLD OF A REAL TECH AT A SUZUKI DEALER HE THINKS WITH THESE READING TO REPLACE THE RECTIFIER SO ONE IS ORDERED THANKS FOR THE ADVICE"
