Had mechanic replace exhaust manifolds, risers on starboard engine after a leak caused bent push rods on #8 cyclinder. All checked out great after work completed; compression check, temps checked alll running fine. Ran boat to new dock location, 1 1/2 hours, temps 165, pressure 60 lbs. 2800/3200 rpms. Next time to boat checked oil, good color but showing about a 1/2 qt. high. Checked heat exchanger overflow tank, same level as always. Started enginge oil changer to draw down oil over level and found water! Pulled filter, more water! Sent oil sample= sea water. Called mechanic to repair! They pulled each exhaust manifold/riser off as a unit and bench checked for pressure and correct flow, all seemed fine. They theorized that the sea water was getting back into the engine from the exhaust cross over tube. They put longer connectors between risers and crossover (all original exhaust system, no problems over the last four years). This past weekend, I replaced the oil cooler, flushed oil and filter twice, and went out for a 30 minute trial run. Same situation, oil look 1/2 qt. over full on dip stick, filter loaded with sea water.
Where do we go from here? Any suggestions would be of great value.
