"Hi guys. New here, and I appr
"Hi guys. New here, and I appreciate your feedback. 1989 454/330 Crusader running hot above 3000 rpm and when under a load. Closed system.
Step 1 - strainer clean.
Step 2 - back flushed seacock for 30 minutes. flow seems strong.
Step 3 - rw pump belt new and tight.
Step 3 - inspected raw water impeller. looks fine. pump housing looks fine.
Step 4 - disco rw feed to oil cooler. pumping water strong.
Step 5 - disco rw outlet from oil cooler - strong flow.
Step 6 - remove exchanger end cap - looks clean.
Step 7 - remove tstat and tested on stove. works fine and opens at 150.
Step 8 - replaced water hose from seacock to strainer. (soft spot).
Flow inside exchanger seems light. Any chance the water pump on the block is bad? No leaks anywhere.
Hoses all seem fine. AF is clean and 50/50 mix. Engine always runs at 150 until last week. Risers/Elbows 2 years old. Running at lower rpm's under load causes slight rise, but not mor than 160-170 degrees or so. 3200 rpm means 200 and alarm condition. drops to 150 after a few minutes at lower RPM
Thanks guys."
Thanks guys."
