diddlysquat
Power trim on my 1988 125hp Marine Force has short planing piston and two longer trailering pistons. If my motor drifts down by gravity do the O-rings need replacing on the trailer ones? Or is it a separate issue. Last season I took apart the assembly for the short piston and because some O-rings/seals/bushings can’t be replaced I switched out to a C-clip bushing/ring and not sure if it’s leaking. I believe my boat is planing ok on the water. If I understand correctly any O-rings leaking means internally the hydronic fluid moves throughout the enclosed system when not sealed at every ring? Hoping someone can suggest what the fix is. Thanks
