denginenut
I have a 1987 Johnson 9.9 J10RCUE that will not run. Great compression and good blue spark. Seems to be a fuel problem. Fuel pump is working. I tried to blow through the fuel line that connects to the carb and it is stopped up. I assume you should be able to blow through this hose. Where do I go from here? What is the procedure for removimg the carb from the power head?
Thanks for any and all help.
