M
Msutphin
Guest
" Problem began and acted just
" Problem began and acted just like a power pack went out. I replaced both and problem was still present (will start and run up to 2500rpm then shuts down). 1st mechanic started at fuel tank replacing all lines, filters, rebuilding Carbs. Compression check showed almost new readings. Kept boat 4 month trying all he knew and no fix. I brought boat home and tore it down to th powerhead, new gaskets everywhere, could find no cracks or indications of leaks, new wiring now, carbs rebuild second time, etc. Still no fix. Second mechanic concentrated on electrical including regrounding everything. He gave up after 3 months. Getting plenty of fuel to carbs, pumping bulb doen not help. Currently it starts and runs great up to 2500prm but try to go over the 2500rpm and it dies just as it is starving for fuel. Any ideas? "
