1985 15 hp Evinrude
M
Mike Veres
Guest
"Prop slips at high speed, I r
"Prop slips at high speed, I replaced the prop but still have the same problem. engine kind of surges just before prop slips"
More info required-----First t
More info required-----First time on a new boat???Transom height is??? Short shaft motor on a 20" transom???
"Had the motor for two years o
"Had the motor for two years on the same boat. Boat has a 16" transom.
I only had the motor for two years, it ran fine last year, started slipping this summer. It looked like the original prop on it so I changed it out with the same results. There is usually three of us in the boat with a combined weight of 600lbs + not including gas tank tackle boxes coolers etc. Maybe the motor is pushing to much weight?"
So mark the prop and the hub a
So mark the prop and the hub and see if the marks are still lined up after a run.
