Brandon Lang
Hello all,
I am seeking help and info on possibly replacing the prop shaft seals on my Mariner. Got some gear oil coming from behind the prop due to (I think) some fishing line getting in there. After taking the prop off I dug it all outta there and then ran the motor with earmufs on and didn't see any leakage but left everything off overnight just in case. Nothing came outta the front seal but some oil seeped out from behind. I figure that I have to either think it's the inner seal or the O-Ring. The Cover Nut comes off easy enough without causing any damage because of little or no corrosion (very low hours). Where do I go from here? Is it something simple or am I going to cause bigger problems if I try and fix myself?
