J
John Burbank
Guest
" What would be the correct vo
" What would be the correct voltage output for my 1968 55 HP Evinrude?. I had problems keeping a charge on the battery in the past. and want to clarify it before I get it in the water. I currently run 12.40 to 12.65 volts at the battery terminals during a flush test. I was assuming it would be in the 13 to 14 volt range like for a car. Maybe I am wrong.
I Followed your directions from a previous posting on checking the stator, rectifier etc. I believe they all passed the testing. I replaced the rectifier last year and recently re-placed the corroded/bad wiring in the harness from the boat to motor plug connection. The boat fires up and appears to run fine with a fully charged battery. Any clues would be greatly appreciated. "
