[email protected]
I'm replacing the crank on my engine. The current Parts diagram on MarineEngine.com shows only 1 O ring (Part 20) on the lower end of the crank. I have a parts diagram from an older service manual which also shows an O ring on the upper part of the shaft. My casing engine did not have an O ring installed at this location but there is a casing groove that would allow it. Should there be an upper O ring installed on the upper end or has the design been changed to rely only on the upper seal? Thanks.
