robertmotz
I have an intermitant alarm that goes off after the engine has ran for a while,could be 1 hr. at higher rpms or after 15mins. after crossing the lake,I slow down and at slow speed the engine will run ruff,like on 5 cylinders instead of 6 and the alarm goes off with a beep-beep-beep alarm.It does not do it all the time.If I shut the engine off and restart, the alarm will go off if I start slow, but if I restart and go full throttle 95% of the time no more alarm.At higher rpm's I could be cruising at 4500 rpms for 45 mins. and then there will be a small drop in power and rpm's and then that intermitant alarm again.Seems if I run at higher rpm's ie.4800-5000 the less likly hood the alarm will go off.If I'm in big waves and riding the throttle back and forth there is also less liklyhood that the alarm will go off at all.I spent 2 weeks on the ocean and with the fishing close I went 4-5 days without the alarm going off at all ,but if I'm travelling longer distances more likly it will go off .I took it to the dealer and these alarms don't show up on the computer,and they couldn't duplicate the symptom.Any sugestions out there???
