Robert Pastor
Hi All,
I hpe one or more of you can help me. I changed water pump, now there is no telltale. I tried muffs, a barrel full of water still no stream. Pulled LU and checked impeller, key, seal, and lower water tube grommet. All good. Put hose on water tube and now get a nice stream. Put everything back and...no stream. I decided to check the thermostat. Put engine in barrel, started it and as soon as I pulled the hose off the therm housing, stream started, back on, no stream. No water coming from therm housing. It seems as if there is something blocking the water tube and the hose water pressure is enough to force past it but the water pump pressure is not strong enough. Any ideas?
