Results 1 to 3 of 3
    Default marine power 340HP wiring diagram and DLC connector location needed 2008, MEFI
    i am working on a 2008 marine power and it started fine this season, but once in the water she died after running like crap, now i get no crank, dash info says no power detected from ECM. i looked all over the place and can't find the DLC connector to plug the scanner in and check the ECM. i did find 3 wires tied back by the ECM with wire conectors on them, orange, white and blue. i am thinking the conector should be there and the PO did something. the boat is new to my customer this season.
    also, if anyone knows were the engine info is located, i would like to see that as well. its a small block engine so im guessing its a 6.0
    i checked poower the the main breaker on top of the engine, thats ok, battery is good, i jumped the starter and the engine spins. but turning the key gets nothing, no fuel pump hum, no solenoids clicking.
    thanks guys
    Jun 2008
    Island Heights, NJ,
    3,617
    Default Re: marine power 340HP wiring diagram and DLC connector location needed 2008, MEFI
    Not an ECM kind of problem... find out why there is no power either to or from ignition switch start circuit to engine.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    ok, ,so i finally found the DLC connector and sure enough, no ecm found, so i am now trying to run down why suddenly she would run poorly and then shut down completely with no power to ecm after that.
  1. Help - what is this MEFI-4 Connector?
    By OnPlaneDrifter in forum Crusader Marine Engine Forum
    Last Post: 12-01-2020, 09:28 PM
  2. Mercruiser 350 MEFI power issue help needed (2000 Maxum 3300SCR)
    By Intelleq in forum Mercruiser Sterndrive Forum
    Last Post: 10-20-2011, 09:19 PM
  3. wiring diagram for a evinrude 1976 40655r needed
    By donfordguy in forum Johnson Evinrude Outboard Forum
    Last Post: 09-12-2010, 10:51 AM
  4. wiring diagram for the Honda bf20 2008 ( 20 hp )
    By jasoncalleja in forum Honda Outboard Forum
    Last Post: 05-31-2010, 10:32 AM
  5. Wiring diagram for EDC type 1 marine KAD44P
    By govie in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 12-03-2007, 02:26 PM
