Click for Honda Manuals, Parts and Model Guides!
Results 1 to 10 of 10
Thread: Honda BF60
  1. #1
    Default Honda BF60
    Hello,
    I have a BF60 with MIL 41 code. HO2 Heater Sensor that won't go away after replacing the sensor. The Ohm resistance is 7.1 cold. I also checked power to the harness and it's 14.4v. have cleared the code and reset many times but it keeps coming back.
  2. #2
    Default Re: Honda BF60
    I'm getting 4 long beeps followed by 1 quick beep. That indicates code MIL 41 and not 4-1 right?
  3. #3
    You're aware there are 2 water temp sensors, yes?
    Is it your impression that the motor is actually getting hot?
    Does it going into "limp" mode where it's dropping rpm?
  4. #4
    The motor runs fine, no overheat, and no limp mode. Just keeps getting buzzer for code 41 Oxygen sensor Heater Circuit. Put a new Oxygen sensor in with no luck.
  5. #5
    Join Date
    Apr 2018
    Posts
    1,512
    If you. have full voltage to the sensor and you have checked continuity of the Bl/wh between the sensor plug and the ecm plug then you can be certain you have a faulty ecm.This is where a dealer can help, they can try a good ecm to confirm the problem before you send a lot of money replacing it.
  6. #6
    Join Date
    Apr 2018
    Posts
    1,512
    As a matter of interest, what year is your motor and how many hours has it done?
  7. #7
    2019 around 100hrs
  8. #8
    Join Date
    Apr 2018
    Posts
    1,512
    So it's under warranty, I suggest you don't fiddle too much
  9. #9
    I am currently running a Deep Cycle Battery that has 500 CCA. Honda recommends one with at least 582 CCA. Could something like this cause it to throw a oxygen heater code 41?
  10. #10
    Join Date
    Apr 2018
    Posts
    1,512
    No, not at all
Similar Threads
  1. 2019 Honda Bf60
    By Tn_le in forum Honda Outboard Forum
    Last Post: 06-06-2021, 04:53 PM
  2. Replacing a Honda BF50 with a BF60
    By Larry W D in forum Honda Outboard Forum
    Last Post: 01-23-2020, 02:53 PM
  3. How hot can Honda BF60 run..?
    By Jussia in forum Honda Outboard Forum
    Last Post: 11-14-2017, 03:26 AM
  4. No Tilt/Trim Honda BF60
    By mixman in forum Honda Outboard Forum
    Last Post: 08-20-2016, 09:51 AM
  5. New Honda BF50 or BF60 for trolling?
    By jmomc345 in forum Honda Outboard Forum
    Last Post: 06-10-2012, 12:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
