Results 1 to 4 of 4
    Default AQ 280 mechanical tilt problem.
    I have a 77 Bayliner in beautiful shape. It has an AQ280 drive on it and my problem is that the mechanical tilt will power up but not down. I have power from both directions on the switch. All wires are connected in the relay box. Any suggestions?????
    Dave
    Jun 2008
    Island Heights, NJ,
    3,622
    Default Re: AQ 280 mechanical tilt problem.
    There are two relays under the black cover on top of the lift out (not tilt) mechanism.... one is for up the other for down.
    Likely one of them is bad.
    If you pm me your email address, I send you a copy of the OEM shop manual which has the schematic.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    Quote Originally Posted by sandkicker View Post
    Thanks for getting back to me. The one thing I hadn't checked, tonight I did, was the limit switch. It was stuck. Works now.
    Jun 2008
    Island Heights, NJ,
    3,622
    Quote Originally Posted by ryanpilotdave View Post
    The adjustment of the limit switch is somewhat critical... it is threaded into the top of the housing. Sometimes incorrect adjustment results in the threads in the housing being stripped. Normally this is an expensive repair, i.e., new housing. However... on one of my boats, I was able to rig a "Z" bracket that held the limit switch in its correct position
    Capt Bob
  1. 1974 OMC 400 Stringer Tilt up works, Tilt down is the problem
    By bresecker in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-29-2016, 09:29 PM
  2. 2001 30hp will not lock into shallow mechanical tilt properly
    By voyagerltd in forum Mercury Mariner Outboard Forum
    Last Post: 04-02-2014, 08:20 AM
  3. Replies: 12
    Last Post: 07-01-2011, 04:00 PM
  4. 280 mechanical tilt
    By 43_lx_merc_1996 in forum Volvo Penta Gas Archive
    Last Post: 02-18-2008, 07:11 PM
  5. 43 Wonbt StartElectrical or Mechanical Problem
    By Paul Marshall in forum Volvo Penta Gas Archive
    Last Post: 12-31-1969, 07:00 PM
